Started working erratically on 7/24/2021 at 16:07 utc. Please see attached helicorder image and log file.
After reboot it will work for a short time then stop.
I replaced the micro sd card and it’s now working as it should.
Hello JonR,
Thank you for the logs. From them, it appears that were many errors such as this one
Jul 26 14:38:37 raspberryshake kernel: [26496672.026014] ttyS ttyS0: 1 input overrun(s)
or communication issues between the sensor and the boards on the Shake like this one
|2021 207 15:17:35>>|„U|
|2021 207 15:17:35>>|!„«QÁTIàEÏÔUUXE|
|2021 207 15:17:35>>|”e‹dŧÔEmªQmIIàDc AaÂEE|
|2021 207 15:17:35>>|!U|
|2021 207 15:17:35>>|1Æ«W\XIЫÔU1•E|
|2021 207 15:17:35>>|!UE|
|2021 207 15:17:35>>|ŠQ|
that ultimately indicated some kind of corruption going on on the microSD card. It could have been caused by a multitude of reasons, such as a sudden drop in the voltage/current.
The solution you have applied, to replace the microSD card is the one I would have advised, so well done, and great to hear that the Shake is working properly again!
