I have been operated my raspberry shake few days ago.
The operation seems likely ok. However, I have server satatus “disconnected” and I couldn’t see my station on station view.
Data producer : on
Data consumer: on
Data provider :on
RSH.RD5B6.2023-07-05T05_29_44.logs.tar (1.4 MB)
Regards,
Paiboon
Hello Paiboon, and welcome to our community.
Thank you for contacting us about this issue you are experiencing, and for sending the logs from your Shake.
It appears, from them, that the Shake cannot find a way to communicate with the server, as shown here:
2023 185 09:51:08>> Connection attempt #1 (raspberryshakedata.com:55556) failed with error code: No route to host
On this, I would like to ask you to check if ports 55555 and 55556 are open on your router, and if not, to open them. As there are hundreds of different router models/makers, I cannot offer precise guidance, but you should be able to find how to do so from the router manual and/or from your router admin panel.
Those ports are essential to communicate with our data servers, so it is required for them to be open in TCP if any Shake wants to transmit data to us. You can find a full list of ports that need to be open here on our manual: Firewall issues?
Once you have done so, please reboot both the router first, and then the Shake, to see if it now manages to connect. If not, please download the new logs and send them to me, so that I can make further checks.
Hi Stormchaser
I have tried several ways even change to another ISP. The result are the same, internet connection was not possible. I have also change the new router supplied by the ISP, it doesn’t help. The ISP told that , no any port closed.
I seems likely that the problem not coming from router. It should from the raspberry shake itself.
Please suggest me , how can I go further.
Thanks,
Paiboon
Login to your 'shake using ssh.
On the command line see if you can ping the remote system:
myshake@raspberryshake:/opt $ ping 144.91.66.87
PING 144.91.66.87 (144.91.66.87) 56(84) bytes of data.
64 bytes from 144.91.66.87: icmp_seq=1 ttl=55 time=184 ms
64 bytes from 144.91.66.87: icmp_seq=2 ttl=55 time=190 ms
64 bytes from 144.91.66.87: icmp_seq=3 ttl=55 time=184 ms
64 bytes from 144.91.66.87: icmp_seq=4 ttl=55 time=196 ms
^C
--- 144.91.66.87 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 7ms
rtt min/avg/max/mdev = 183.555/188.459/196.401/5.243 mstype or paste code here
If that doesn’t work, see where the failure occurs using traceroute:
myshake@raspberryshake:/opt $ traceroute 144.91.66.87
traceroute to 144.91.66.87 (144.91.66.87), 30 hops max, 60 byte packets
1 10.0.0.1 (10.0.0.1) 2.709 ms 2.919 ms 2.872 ms
2 50-209-43-154-static.hfc.comcastbusiness.net (50.209.43.154) 6.505 ms 6.845 ms 6.811 ms
3 96.120.60.177 (96.120.60.177) 43.951 ms 43.849 ms 43.864 ms
4 68.85.148.37 (68.85.148.37) 43.697 ms 16.092 ms 43.698 ms
5 po-100-xar02.salem.or.bverton.comcast.net (96.216.60.209) 21.754 ms 43.595 ms 43.576 ms
6 ae-75-ar01.troutdale.or.bverton.comcast.net (96.216.60.221) 49.747 ms 48.527 ms 20.141 ms
7 4.68.37.245 (4.68.37.245) 29.299 ms 23.838 ms 29.190 ms
8 ae1-3121.edge8.Frankfurt1.level3.net (4.69.158.186) 180.932 ms 180.890 ms 176.271 ms
9 GIGA-HOSTIN.edge8.Frankfurt1.Level3.net (62.67.36.138) 202.877 ms 202.791 ms 202.787 ms
10 ip-87-66-91-144.static.contabo.net (144.91.66.87) 202.703 ms 202.230 ms 202.551 ms
If those work, they you have network connectivity to the system you are trying to connect to.
Next, try the specific port:
myshake@raspberryshake:/opt $ nc -zvw5 144.91.66.87 55555
Connection to 144.91.66.87 55555 port [tcp/*] succeeded!
This should give you a clearer idea of what is going on.
You can also try these commands on another system connected to the same network.
You can at least run the ping and traceroute on a Windows machine (traceroute is called tracert on Windows) - I don’t think Windows has Netcat (nc).
Hi Philip
Using ping command it didn’t work.
Trace route is ok.
Assigned port didn’t work. Failed: No route to host.
92.38.148.70 is my ip address that provided by the ISP.
regards,
Paiboon
You are not using the correct IP address. It is 144.91.66.87, not 92.168.1.70.
Dear PhillipPeake
I have used 144.91.66.87 the results are below:
Paiboon
PS: I have tried pinging that connected in the same network with another equipment, it works
Thank you Philip for suggesting those checks, and thank you paiboon for executing them.
It definitely appears that there is some kind of communication issue between the Shake and our servers, as no command is answering positively.
At this point, I would say that we can try to reset the Shake with a new re-burn, and then re-start our checks from there. Could you please re-burn your microSD card and see how the Shake behaves with a freshly-installed system? I will leave the burning instructions here for your convenience:
- Make sure, when you format it, that the shown capacity is the maximum (i.e. if the SD card is 32GB, then the capacity should be near or equal to that value). This is to check that no partitions have been involuntarily and erroneously created. They could be the cause of the error we see now
If the Shake connects, then there was something in the software that got fixed by the fresh re-burn. If not, then please send me again the following:
- the new logs from the Shake
- the output of the command
ping 144.91.66.87 - the output of
traceroute 144.91.66.87 - the output of
