Hello waw0102, and thank you very much for the logs!
For all three Shakes, it appears that, while they manage to find a good internet connection, they cannot retrieve NTP time data, as shown below:
2024 145 00:43:30: NTP failed to start
Without NTP services, the time on the Shake cannot be precisely synchronized and will not appear on our network.
You can check the dedicated port
123 [UDP] - NTP, necessary for time-stamping seismic data
and open it on your network if closed.
Also, it appears that the server connection ports are closed, so I would recommend checking again with your local network and opening the following ports:
* raspberryshakedata.com:55555 [TCP]
* raspberryshakedata.com:55556 [TCP]
Once all of these have been checked/opened, you should reboot the Shake again, and they should now be able to connect. If required, you can find more information on ports here: Firewall issues?
If not, please wait for about half an hour, download the new logs, and send them to me to see what else we can do.
