Hello, based on previous posts with this issue, I believe my IP may have been banned from the server due to previous ISP connection issues. This occurred in early Nov while away on vacation and home network connection was going on and off repeatedly.
I have successfully rebooted the unit and everything looks good locally with Off-Line mode off and Data forwarding on but no server connection.
Ping to 8.8.8.8 is successful.
Ping to 104.200.16.60 Fail with 100% packet loss.
Log file included below. RSH.R8599.2021-11-24T14_07_06.logs.tar (2.0 MB)
Any assistance with getting my unit back online would be greatly appreciated. Thank you!
While the unit was set for data forwarding, I turned data forwarding off and saved/reset the unit. Then turned the data forwarding back on and reset. Cycling the data forwarding off then back on has fixed the server connection issue. Thank you for your assistance!
