Server Connection Fail
Hello, just finished setting up my RS, I can see data on the RS web dashboard, however, Server Connection shows inactive, so it does not appear on stationview, I have verified that the Data Sharing is on and that the RS has internet.
Any idea on what could be wrong here?
logs:
RSH.R8F74.2026-10-28T08_21_44.logs.tar (1.8 MB)
hello opdas12,
we want to help you get your unit online. can you please provide some background information for this RS1D:
  • where was it acquired from?
  • when did you receive it?
  • has it ever connected before?
  • what DIY work, if any, have you carried out?
  • can you send some photos of the unit? this would help us identify what could be going on.
  • what’s the temperature today in antarctica?
once we have some more information from you, we’ll be able to investigate this in more depth.
thanks in advance,
Thanks for the response!
I got the board from a 3rd party that sold it to me (marketplace), it came with an sd card and i assumed it was enough to get it running, but it seems like there was some corrupt software, i reflashed the SD image and checked the board connections with the pi, and now the RS is reporting data correctly to the server.
hi opdas12,
glad it was an easy fix, i do see that you are connected to the server now. however, the data looks very strange. given that this was purchased from a 3rd party, we would like to investigate the unit a bit further to determine what could be going on with the faulty data we are seeing.
to that end, can you please provide us some more info?:
  1. pictures of the board itself, both sides
  2. a description and pic of the geophone that you are using
  3. download and re-send the most recent log files from the unit
thanks in advance,
