Hi everyone,
this is my first post on the forum.
I just switched on my RS1D at home to perform some tests, it seems to work perfectly out of the box
I plan to use the RS1D for a structural monitoring application, which requires the use of an horizontal geophone instead of the vertical one.
The current vertical geophone in the RS1D seems to be a 4.5 Hz 395 Ohm vertical Racotech RGI-20DX, electronically extended down to 1Hz as described in the spec sheet.
I guess that I must find an horizontal sensor with the same caracteristics (eigenfrequency, resistor, no damping shunt, same sensitivity of 23.4V/(m/s)?
Would you recommend any brand? (maybe sticking with Racotech would be a good idea?)
I also have three minor questions which come as a following:
-> is there a simple way to rename the channel from EHZ.D (actual code for vertical channel) to EHN.D or EHE.D (once the horizontal sensor will be setup), for example?
(I can do it afterwards using obspy in /opt/data/archive/ otherwise)
-> would it be possible to use geophones with lower eigenfrequencies (e.g. 1Hz) and higher sensitivities (e.g. 80V/(m/s) or 200V/(m/s)) in order to get clearer ambient noise measurements?
I think it will interfere with the electronic correction and sensitivities, so that the waveform may be distorded? And the instrument response will not be accurate anymore.
-> Using the RS3D, is it possible to replace the Z sensor by a third horizontal sensor?
I plan to use 3 geophones each in a landcase, installed on 3 different structures and connected to the RS3D with a few meter-long cable for each.
Thank you for your help,
and for designed such a tool!
Best regards
Pierre
