Rsudp "PyQt5 module not found."
gddeen@RPI5Shake2:~ $ conda activate rsudp
(rsudp) gddeen@RPI5Shake2:~ $ rs-client -h
Qt import failed. Trying Tk…
detail: No module named ‘PyQt5’
R A S P B E R R Y S H A K E
UDP Client
by Ian Nesbitt
GNU GPLv3 2020
Do various tasks with Shake data
like plot, trigger alerts, and write
to miniSEED.
Requires:
- numpy, obspy, matplotlib 3, pydub
I’m using an RPI 5. The newest Bookworm linux uses Wayland and not Qt, X display.
Hello gddeen, and thank you for the notification.
I am going to replicate this on my local Raspberry Pi 5 to see if there is a quick solution I can offer.
Thank you for your patience.
THANKS,
I kinda thought for a second… -h is help.
I took that out and it worked.
I did go searching for the Python code that is running and I didn’t find it. miniforge3/envs/rsudp/bin
rs-client imports main from rsudp.client. But I don’t know where this code is located. I downloaded the source and will just forge through it until I understand it.
This rsudp really works great.
I have a 256 wide by 64 high RGB display controlled from a RPI 3B+. I’m going to have it display the “count” waveform, or the frequency display. I have two shakes and many places to display the information.
Gary Deen
rsudp is pretty cool…
On starting rsudp and specifying a station, read_inventory() fails with a certificate error.
https://fdsnws.raspberryshakedata.com/fdsnws/station/1/query?network=%s&station=%s&level=resp&nodata=404&format=xml
This call is within raspberryshake.py in the rsudp source directory of rsudp-master zip file.
The displayed error is:
2024-11-02 00:42:25 [get_inventory] ERROR: Inventory fetch failed!
2024-11-02 00:42:25 [get_inventory] Error detail: HTTPSConnectionPool(host=‘fdsnws.raspberryshakedata.com’, port=443): Max retries exceeded with url: /fdsnws/station/1/query?network=AM&station=R8D37&level=resp&nodata=404&format=xml
(Caused by SSLError(SSLCertVerificationError(1, “[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: Hostname mismatch, certificate is not valid for ‘fdsnws.raspberryshakedata.com’. (_ssl.c:1000)”)))
This error occurs because the certificate is signed by raspberryshake.org instead of fdsnws.raspberryshakedata.com.
I’m investigating how to specify trust for this site on my RPI linux.
hello,
this URI has changed. the solution is to udpate the FDSN service URL as per the following:
to : https://data.raspberryshake.org
further details on the FDSNWS service for the AM / Shake network can be found here.
hope this helps,
I’m adding the continuous plotting window created by rsudp to be displayed on an RGB matrix. This matrix is 256x64 RGB leds. I installed rsudp on the RPI 3B+ which drives the matrix. I modified c_plot.py in mainloop to save each image to the logdir. I was thinking to add a Module, but that really only gets ALARM messages. I could have updated rsudp with a new ‘FRAME’ message passing the filename of the saved png plot, or passed the entire png in the message. But, I think messages are 4k max, so I skipped that. I looked for the logdir so I could reuse that directory instead of screencap. I think my tmp directory is in RAM, where logdir is, so it doesn’t wear out the sdcard by writing every plot. My RGB program can look for changes to the file and update from that. This is kludgy. Ugh. But, I own a hammer and not afraid to use it.
I didn’t see any natural way to change rsudp to handle getting every plot. I also didn’t see much need in adding the feature if it hasn’t been added by now, nobody needs this feature except me.
I forsee changing the plots so they look better on the display. At that point, I guess I should hackup rsudp and rename it. Or, move the plotting part of rsudp into a new Module. Ideas? I know it has been years since this was written.
Below is my change to mainloop. It was the smallest update I tried.
        in c_plot.py: see 'gdd' added line to save every screen plot to logdir as single file
        def mainloop(self, i, u):
                The main loop in the :py:func:`rsudp.c_plot.Plot.run`.
                :param int i: number of plot events without clearing the linecache
                :param int u: queue blocking counter
                :return: number of plot events without clearing the linecache and queue blocking counter
                :rtype: int, int
                if i > 10:
                        linecache.clearcache()
                        i = 0
                else:
                        i += 1
                self.stream = rs.copy(self.stream)      # essential, otherwise the stream has a memory leak
                self.raw = rs.copy(self.raw)            # and could eventually crash the machine
                self.deconvolve()
                self.update_plot()
                if u >= 0:                              # avoiding a matplotlib broadcast error
                        self.figloop()
                        plt.savefig('/tmp/rsudp/rsudpPlot.png', facecolor=self.fig.get_facecolor(), edgecolor='none') # gdd save every plot
                if self.save:
                        # save the plot
                        if (self.save_timer > self.save[0][0]):
                                self._eventsave()
                u = 0
                time.sleep(0.005)               # wait a ms to see if another packet will arrive
                sys.stdout.flush()
                return i, u
