hi all,
i was wondering if it is possible to receive data through rsudp from several seismographs of the network simultaneously and if so, how should i specify a specific station within the rsudp setting file.
thanks in advance!
Hello torresdrl, welcome to our community!
At this time, our RSUDP is designed as a 1-on-1 monitor. That is, one RSUDP installation is able to monitor the live UDP stream from a single Shake.
However, as indicated in another topic here on the forum, you can check out this alternative approach:
Also, if you find something useful, please share it with our community, as other users may find it helpful. Thank you for your interest in RSUDP!
EDIT: also, while discussing with our software team, there is also the possibilty to monitor multiple channels of multiple Shakes with the multi-stream functionality of DataView (only, for now, if the Shakes are connected and streaming via internet).
Just go to https://dataview.raspberryshake.org/ and then click on the
icon high on the right.
Then, it’s all a matter of finding, dragging, and dropping the channels/Shakes that you want to visualize, and you’re ready to go.
