RS3D No longer able to see Z component via obspy or RS community in swarm
I have not been able to view the Z component from my RS3D (since approximately 19:00 UTC on November 1st) from either obspy or RS community CAPS in swarm. However, I can see the E and N components in both on the methods.
I can view the Z component locally under myShake in swarm, the Helicorder when accessing rs.local in a web browser and dataview.
All is working for times and dates before the that given above.
I have tried re-starting the RaspberryShake, but without success.
Many Thanks
Mark Prescott
RSH.R63B4.2025-11-05T14_29_20.logs.tar (5.1 MB)
Hello Mark, and welcome back to the community!
Thank you for the logs, the Shake is in great shape. This is a server-side issue related to FDSNWS access, so I can assure you that no data is being lost.
An update has been provided here: FDSN server issue - #11 by Stormchaser
Thank you for reaching out, and our apologies for this disruption.
