Hi
My RS3D - AM.R0145.00 is not appearing on the public map (https://stationview.raspberryshake.org/). But when I logged in and use the ShakeNet it appears on the station view.
Regards,
Eugênio Frazão
Hi
Regards,
Eugênio Frazão
Hello Eugenio,
Could you please post the logs from your Shake? In this way, we can take a deeper look at what could be causing this problem.
In case you don’t remember how to do it, they are downloadable from the Raspberry Shake’s web configuration page, accessible entering the rs.local
(or the Shake IP) address in your browser, then by clicking on the “Download Logs” button.
Hello Giuseppe Petricca,
Attached is the log file of the AM.R0145.00 station.
Sincerely,
Eugenio Frazão
Hello Eugenio,
Thank you for the logs. From them, it appears that the booting sequence of the Shake worked properly, but there are some errors in the reading process, from the sensor to the server. Here is an example:
|2021 116 13:45:08>>|No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!|
|2021 116 13:45:08>>|Data has been successfully received, fatal condition resolved.|
|2021 116 13:45:08>>|internal error: buffer overflow! cannot process read data...|
|2021 116 13:45:08>>|buf: {ÿOkˆ|
|2021 116 13:45:08>>|]¤EW'7S Ê”AÐE|
|2021 116 13:45:08>>|2AQ0ÅBqƒaQ|
|2021 116 13:45:08>>|XœÀ|
Can you please shut down the Shake, wait for around 5 minutes, turn it on again, and then let it run for 6-12 hours. Then, download the logs again and post them to me. I want to see if this is a one-time instance, or if, as I suspect, there may be some error in the process.
Good Morning! We’ve already turned off the raspberry and formatted the SD-CARD but it still didn’t appear on https://stationview.raspberryshake.org/
Hello Eugenio,
Could I have the logs of the Shake after the format that you have done? I want to check if there are any differences compared to before.
Follows * .LOG file of the AM.R0145.00 station.
OBS: Also follow the station’s IP http://138.255.28.202:8081/
Eugênio Frazão
Hello Eugenio,
Thank you for the new logs. We have established that your station is working as intended, and the reason why it is not appearing on the map is related to an internal server problem that we are solving.
I will update you as soon as I have news on this subject.
Thank you for your patience.
Giuseppe Petricca,
Ok. hank you very much!
Eugênio Frazão
Giuseppe Petricca,
The AM.R0145.00 station is not appearing in https://stationview.raspberryshake.org/
Best regards,
Eugênio Frazão
