Dear Raspberry Shake Support,
I have an older RS1D unit from a previous project that was stored unused for several years. I am now trying to bring it back online, and I need help getting it onto my local network so I can access it.
What I have done:
- I flashed a fresh microSD card (128 GB, good quality) with the official Raspberry Shake OS image, using my Mac.
- I inserted the card into the Shake and powered it on.
- I connected it to my router via Ethernet cable.
The problem:
The Shake does not appear on my local network. Specifically:
- It does not obtain or show an IP address in my router’s connected-devices list.
rs.localdoes not resolve in the browser (Chrome and Safari).- A full network scan finds no device with a Raspberry Pi MAC address (b8:27:eb, etc.).
- Port 22 (SSH) is closed across the network.
I have already tried connecting it to a different router, with the same result. I have confirmed the Ethernet cable and ports are working with other devices.
Some context that may be relevant:
- The unit is several years old (purchased for an earlier project).
- I have already lost two microSD cards in this specific unit — I flash them on my Mac (they read/write fine), insert them into the Shake, and afterwards the Mac can no longer read them. This makes me suspect a possible hardware fault in this unit (SD slot or power circuit corrupting cards), separate from the network issue.
My questions:
- Could a faulty SD slot or power circuit explain both the corrupted cards and the unit not booting/reaching the network?
- Is there a way to confirm whether this unit’s board is still functional?
- What power supply specification do you recommend (I am currently using a 5V supply)?
- If the board is faulty, can I reuse the RS1D digitizer board and geophone with a new Raspberry Pi, or what are my repair/replacement options?
I would appreciate any guidance on how to diagnose and bring this unit back online. I can provide the unit’s serial number or any other details you need.
Thank you very much for your help.
Best regards,
