Hello, this is the first time I have tried getting the data from the SD card. I am trying to visualize data from my dad’s shake, so I am not in the same location as the device and am using only the SD card. How should I go about doing this? I am not sure how to extract the recorded data from the SD.
Someone recently asked a similar question.
The first problem is that the shake is behind a firewall, so you can’t directly access it.
One solution is rather than “pulling” the data, “push” it from the shake.
There is a push solution to export the data to Dropbox here: https://github.com/andreafabrizi/Dropbox-Uploader
Hi @livbish1 welcome to the Community.
You might find this section of our manual useful: How to download your data — Instructions on Setting Up Your Raspberry Shake
Thank you @PhilipPeake
Happy weekend,
branden
