The twitter handle entry field only takes alphanumeric characters, so entering my handle ‘rock_jockey’ is impossible.
Hi @rock_jockey - thank you for pointing this out. Would you mind adding the characters "B - " to the beginning of your post title to identify it as a bug? This will allow us to quickly identify and solve them.
hi rock,
not sure what’s going on, but when i tested this, everything works fine. (i even hijacked your handle to make sure my test was the same.) nor can anyone else recreate this.
can you have a look again and see if it might be related to your input device, somehow? can you try on a different computer and see if you get a different result?
Could have been an iPad glitch. It works, as you said.
