Hello
What is the process to dissociate the Shake device from my account, and clear any data before handing over the device to someone else to own and use?
Hello kbax,
We have programmed our systems to give any user total control about their data. You can take these two steps to completely disassociate your Shake from your account.
Regarding the Shake itself, you (or the new user) can format and re-burn the microSD card, so that any data on it will be erased, and the Shake will start as a new unit, just in a different location with a different owner.
This is the procedure to do so:
This will be enough to disconnect that particular Shake from your account.
Regarding the data on our servers, if you log in into your ShakeNet account, please click on your round avatar high on the right, then select User Settings
, and scroll all the way down to the end of the page that loads.
Here, you can still download all the data that you have uploaded, with the dedicated button, or, if you want, you can choose to delete your entire account from our servers, with the red button at the end.
If you choose to do so, we will be sad to see you go, and just ask you to send us some feedback via email to see what and where we can improve to make our service to customers even better. Thank you.
