A colleague and myself both modified repeatedly modified the network config in /etc/network/interfaces
and /etc/dhcpcd.conf
while moving our rs4d from place to place, sometimes using DHCP, sometimes fix IP, sometimes wifi, sometimes ethernet.
I’m now trying to setup at home, on my home wifi (which works fine with other seismometers), without success.
I’ve tried both How to configure Wifi and USB wifi dongles from command-line — Instructions on Setting Up Your Raspberry Shake and the webfrontend. At best, after following the shell procedure (including reboot, and ethernet disconnection), it does pop up on my local network for a minute when disabling/enabling wifi, and for a minute after each reboot. The logs are attached…
I suspect that we messed up too much with our config. Is there a way to reset all config files to default?
Cheers
Fred
rsh.logs.tar.bz2 (189.1 KB)
