Hello!
Is a Raspberry 2 absolutely sufficient for a RS&BOOM? It is currently running on a Raspberry 4 / 2 GB RAM and I would like to change it to one that is on the lower end of my available Raspberrys. I also have a Raspberry 3 available as option.
Thanks for advice!
Chris
Hello Chris, and welcome to the community!
We would recommend not going below a Pi3 for improved data processing capabilities, but our Shakes are compatible with Pi2 too.
Here you can find a list of compatible board models that will work with our boards (just scroll to the RBOOM and RS&BOOM section): Technical Specifications
Remember that by changing the board of the Shake, the Shake name (code) will also change.
