Hello Peter,
Thank you for the logs. From them, yes, it seems that there is something strange going on. I’ll explain. When the Shake starts, your router automatically gives it the following IP address:
Retrieving IP Address of interface eth0: 192.168.88.254
However, when the connection to our servers is established, it unsually change to this value (again, assigned by your modem/router):
inet 192.168.0.116
with this DNS server 192.168.0.1.
Now, the difference between these numbers means that for some reason, the router assigns two different LAN IP addresses, and this causes the problems that you are experiencing.
Something that you can try, if you haven’t already, is to shut down your Shake first, then your modem/router. Wait for 2 to 5 minutes, then restart your modem/router, and when it’s back online, please check from your pc/laptop if the following ports are open (do not start the Shake now) if you can:
port 55555 [TCP]
port 55556 [TCP]
After checking this (sometimes the modems close them without prompting) and opening the ports, if needed, please start your Shake, wait for around 10 minutes, and check if now you can find your Shake in your network.
Also, please download the logs again and attach them to your answer, so that I can check for any difference, if there are.
