We have a RS1D (RD3AF) in an Institute. On julday 155 it had some network issues, and multiple data gaps occurred during this day. These issues were resolved and RS was rebooted, now it is recording data and has network connection. Every night it copies data to an external owncloud disk, but it seems to have been locked in the system. Could you check this? Would it be possible to unlock it?
Great to hear that you managed to solve the issues with your Shake. The IP address associated with that station has now been unlocked. Have a great weekend!
A few days ago the station RD3AF was blocked again, at least it doesn’t connects to the server. This time I obtained the log files before writing, please find them atacched.
After checking, we have unblocked RD3AF in our server. It appears that new network issues that were causing network destabilization appeared aorund 10 days ago, and the station was precautionarily banned.
From the logs (thanks for sending them), nothing is out of place with the Shake, which boots and operates nominally when the server connection is available. If you still don’t see the Shake online, please reboot it (alongside with the local router, if needed) and it will show on our services.
I would also recommend to please check in with the owner/where the station is located, and see what can be causing the network problem on your side. Until these problems are located and fixed, complete connection is not guaranteed, as you have seen during these years.
Thank you very much for your fast answer. The station is in a high school, I don’t see it online yet, so I asked the teacher to reboot the RS manually, but till next monday they will not be able to do it…
Now they are preparing to close for summer hollydays, so it will be difficult to figure out what happens with their network, it should work better now that there aren’t students using it…
If next monday it dosesn’t reconnects I will ask them to dismantle it, and we will see after Hollydays.
Thank you very much for your support, have a nice weekend!
Mario
