germen
November 6, 2019, 12:44am
1
Hello, I´m pretty new working with RBOOM for infrasound. I tried to stream the data to Seiscomp3. I download the “RBmV3-1s.dataless” (does anybody know where I can found more info about the XML tags), I touch just the fields with XXX and replace that with the name of my station.
After import, test sync, sync and sync keys under the Bindings I got a new network “AM” the question here is which channel I need to put under the global, for a seismic station is working with BH, BHZ… But with the Boom, I don´t have Idea.
This sounds familiar to someone?
Good day Germen:
Welcome to the Raspberry Shake Community.
What is the ID of your Raspberry Shake?
Yours, Branden
germen
November 6, 2019, 4:39pm
3
Hello Branden thanks for your reply… My Id is AM.RC170.HDF.
Thanks
Germen
OK, I see that you do not have Data Forwarding enabled. Is the data somehow protected for business reeasons?
Yours, Branden
germen
November 6, 2019, 5:46pm
5
Nope, its for a PHD research from the University of Guadalajara in Mexico.
Is sharing the data publicly an option?
I am asking because if you do so then we automatically generate the instrument response file for you in SC3 format.
Note: You can have SeedLink and data forwarding on simultaneously. This is the normal modus operandum.
Yours, Branden
germen
November 7, 2019, 3:53am
7
Let’s try then, I’m AFK until next Monday…
germen
November 12, 2019, 2:35pm
8
Hello Branden, I just turned on Fordwarding data option, how long it takes to see my boom on the shakenet.
thanks
branden
November 12, 2019, 2:42pm
9
germen
November 13, 2019, 6:53pm
10
My bad… I was looking on the shakes.
Could you help me to read this using Seedlink. I tried but without lucky.
I just add under Inventory the XML choosing sc3.
Test sync, sync and all looks okay.
I got now a network “AM”.
I made a new global HDF, and then put HDF in the detectStream field
Also a new seedlink “RSLOCAL” Chain - Seedlink server (TCP/IP), rs.local // port: 18000
After dragging and drop those to AM. Save, Update configuration.
scrttv, but i cannot see my boom.
Thanks
Yair
branden
November 13, 2019, 7:55pm
11
Yair:
It sounds like you are almost there!
This also sounds like this is a paid technical support request. Please send us an email at sales at raspberryshake.org and we will send you a quote.
Thank you!
branden
germen
November 14, 2019, 1:34am
12
Dear Branden, I don´t want to bother you but looks like your reply is empty.
Germen
branden
November 14, 2019, 1:04pm
13
Yair:
This also sounds like this is a paid technical support request. Please send us an email at sales at raspberryshake dot org and we will send you a quote.
Thank you!
