I’ve been playing around with different ideas to test for cross channel interference or interaction on the RS&B and finally got my head around the Cross_Correlation functions in Obspy which ATM seems by far the best way to do it compared to what I’ve tried.
This is of particular interest to me to identify and eliminate seismic sources of infrasound signal when trying to detect meteors by infrasound.
Attached is the code I’ve used FYI and use if interested. I’m sure it could be polished up and written in a more elegant manner.
from obspy.signal import filter, cross_correlation
rs = Client('RASPISHAKE')
xc = cross_correlation
stn = 'R21C0' # your station name
inv = rs.get_stations(network='AM', station=stn, level='RESP')
print (inv)
# set data start/end times
start = UTCDateTime(2022, 6, 6, 23, 17, 16.7) # (YYYY, m, d, H, M, S.ffffff)
end = start + 1 # end = start + duration in seconds (S.ffffff)
channels = ['EHZ' , 'HDF'] # ENx = accelerometer channels; EHx or SHZ = geophone channels
# get waveforms and put them all into one Stream
stream = Stream()
for ch in channels:
trace = rs.get_waveforms('AM', stn, '00', ch, start, end)
stream += trace
stream.merge(method=0, fill_value='latest')
stream.detrend(type='demean')
print(stream)
#get instrument response
inv = rs.get_stations(network="AM", station=stn, level="RESP")
# setup figure and subplots
fig = plt.figure(figsize=(12,12))
ax1 = fig.add_subplot(4,1,1)
ax2 = fig.add_subplot(4,1,2)
ax3 = fig.add_subplot(4,1,3)
ax4 = fig.add_subplot(4,1,4)
fig.suptitle("AM."+stn+" RS&B Cross Channel Correlation Report: "+start.strftime('%d/%m/%Y %H:%M:%S.%f UTC'))
# plot raw traces
ax1.plot(stream[0].times(reftime=start), stream[0].data, lw=1, color='g')
ax2.plot(stream[0].times(reftime=start), stream[1].data, lw=1)
# calculate cross correlation
s = 10 # shift in data points each side to test
cc = xc.correlate(stream[0], stream[1], s)
print(cc) # print correlations for each shift value
shift, value = xc.xcorr_max(cc) #find the max correlation and shift
print(shift, round(value,3))
# get the limits of the y axis so text can be consistently placed
ax2b, ax2t = ax2.get_ylim()
#add the correlation to the plot
ax2.text(0, ax2t*0.8, 'Raw Shift = '+str(shift)+'/100 s. Correlation Coefficient ='+str(round(value,3)))
# set up filter
filt = [0.3, 0.5, 10, 12] #edit filter values to suit
# remove instrument response and add new traces to the stream
stream += stream[0].remove_response(inventory=inv,pre_filt=filt,output="VEL", water_level=60)
stream += stream[1].remove_response(inventory=inv,pre_filt=filt,output="DEF", water_level=60)
# plot filtered traces
ax3.plot(stream[0].times(reftime=start), stream[2].data, lw=1, color='r')
ax4.plot(stream[0].times(reftime=start), stream[3].data, lw=1, color='b')
#calculate cross correlation of filtered traces
cc1 = xc.correlate(stream[2], stream[3], s)
print(cc1) # print correlations for each shift value
shift1, value1 = xc.xcorr_max(cc1) #find the max correlation and shift
print(shift1, round(value1,3))
# get ax4 y axis limits so text can be consistently placed
ax4b, ax4t = ax4.get_ylim()
ax4.text(0, ax4t*0.8, 'Filtered Shift = '+str(shift1)+'/100 s. Correlation Coefficient ='+str(round(value1,3)))
# setup some plot details
ax1.set_ylabel("EHZ Raw Counts")
ax2.set_ylabel("HDF Raw Counts")
ax3.set_ylabel("EHZ Velocity (m/s) ("+str(filt[1])+" to "+str(filt[2])+"Hz)")
ax4.set_ylabel("HDF Pascals (Pa) ("+str(filt[1])+" to "+str(filt[2])+"Hz)")
# save the final figure
#plt.savefig(stn+' RSandB Corr'+start.strftime('%Y%m%d %H%M%S UTC')) #comment this line out till figure is final
# show the final figure
plt.show()
This is what the output looks like:
In this case, there’s a 48% correlation between the filtered EHZ and HDF channels and as the HDF signal is leading the EHZ channel by 0.05s it appears to be the HDF channel influencing the EHZ channel.
This obviously works best for short sections of signal. Long sections are likely to reduce the correlation as random noise becomes more significant.
Al.
