Raspberry Boom - How Long?
does it take for the Raspberry Boom to be recognized? I entered rs-2.local/ and get nothing. Just installed it this morning.
Hello Eric,
Firstly, thank you for buying another Shake from us. We hope it will satisfy you as well as your first RS4D!
I can see that your new station is now transmitting live data to our servers. As you had imagined, it can take a bit before that happens, but everything is configured properly now.
Onto accessing the local web interface, usually rs-2.local should work (I have two shakes too, and this is what I use). If it doesn’t, however, you can use an app like Fing (https://www.fing.com/products/fing-app ) to find the Shake IP address (since you have two, there will be two different addresses, and you can try both before finding the one you need).
If Fing manages to find the Shake, you should be able to connect to its web interface by entering its IP address in your browser window.
