I have had a number of problems with the install of my replacement RPShake. The first problem was with an older RPi 2… It had a Ethernet problem and eventually it went deaf after about 2 days. So I tried another and it “kernel panic’ed” every 15 - 120 mins (regardless of the SD card I used and I built several). On to my third RPi 2. This is what the current local web page looks like:
It has no MAC address or name… but it must because I’m looking at the web site. This is the second new build for this RPi. An ifconfig shows:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.162 netmask 255.255.255.0 broadcast 192.168.0.255
ether b8:27:eb:46:7b:0a txqueuelen 1000 (Ethernet)
RX packets 4509 bytes 661535 (646.0 KiB)
RX errors 0 dropped 3 overruns 0 frame 0
TX packets 962 bytes 218311 (213.1 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
and NTP is working well:
ntpq> peer
*hex8.diskworld. 130.217.226.49 2 u 13 16 377 2.067 0.293 0.073
192.168.1.1 202.46.177.18 3 u 5 64 7 2.140 7.397 0.717
+ntp4.ntp.net.nz .GPS. 1 u 55 64 37 28.662 0.898 1.789
+162.159.200.1 10.46.8.10 3 u 55 64 37 13.136 0.214 0.437
-215.96.124.202. .GPS. 1 u 56 64 37 19.493 4.206 0.790
-ntp1.ntp.net.nz .GPS. 1 u 59 64 37 12.470 1.033 1.557
Any suggestions would be appreciated.
Peter
RSH…2019-12-01T21_51_05.logs.tar (121.5 KB)
