So looking at a previous post, I cranked up my Shake device in 2022. Lots of things have changed with Raspberry Pi (the company) in those 4 and more years. Does the Pi need to be updated by using the standard
Sudo apt update
sudo apt full-upgrade
I was pretty ignorant of Pi’s, the OS at the time I built my Shake but it has run faithfully with almost no attention since I turned it on…
Would I benefit from changing out the Pi 4 to a Pi 5 with the Pi5 also using an NVME. I have all the hardware already so the cost factor does not factor into the question
With a Pi5 I can put the OS on the NVMe card rather than relying on the micro-SD card -
Where can I find information about a generic wired network setup for it to function best?
When I first installed my Shake, I had trouble getting the device connected to the internet. I did get it connected but I have a rat’s nest of ethernet cables and power cables I want to clean up. So I could do this all together.
Sort of unrelated but I make these devices called a MagicMirror. Raspberry Pi Company changed from some X11 component to this thing called Wayland. I’m not a programmer so all I know is that this change has to do with how the display window frame works within the Pi OS. Are you all going to have to address that issue also or is how you display your information on screen done differently?
