Hi all,
I’m trying to convert geophone data to find out the displacement from velocity. Ideally, integration of velocity would give displacement. Is there easy solution to do it? for python or Matlab? @iannesbitt
Hi all,
It’s not perfect, but the way I do it in rsudp is:
deconvolve to velocity
from obspy import read, read_inventory
inv = read_inventory('/path/to/resp.xml') # (or use get_stations)
stream = read('/path/to/data.ms') # (or use get_waveforms)
trace = stream.select(channel='*HZ')
sps = trace.stats.sampling_rate
trace.remove_response(inventory=inv,
pre_filt=[0.1, 0.6, 0.95*sps, sps],
output='VEL', water_level=4.5, taper=False)
“integrate” (cumulatively sum) velocity values to get displacement
import numpy as np
trace.data = np.cumsum(trace.data) # end result is in meters
Note: see also info on get_stations()
and get_waveforms()
Thank you @iannesbitt.
