Hi, I was looking at the manual and could not find model/part numbers for the M12 connectors on the outdoor version of the S&B. I am looking at replacing for instance the power connector to run to a battery/solar kit.
Hello Frostburn, and welcome to the community!
There are no specific model/part numbers as the used M12 connectors are produced and sold by different sources that stamp different identification codes/numbers on them.
However, this is a good example of what we use: T4111002031-000 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey and you can use the following keywords M12 Straight Field, Plastic plug 3 Pin, A code to expand your research more, if needed.
Also, if you haven’t already seen this (you probably have), here you can find a PDF with all the specifications for wire connections in the outdoor IP67 M12s: Technical Specifications
