Is it possible to readouts of other parameters from a S&B? I guess cpu temperature or voltage could be easy. But maybe there is a barometric pressure readout from the infrasound sensor?
Thank you
Urs
Thank you
Urs
Buenas noches Urs:
This could be done with a custom script running on the Raspberry Shake’s Raspberry Pi computer, but there is nothing “out-of-the-box” at the moment.
You can use this command to output the CPU temperature, for example:
$ vcgencmd measure_temp
Yours, Branden
