I have two shakes (both are RS3D): one shake is currently connected to the network and serving data online (we’ll call this the “online shake”). I am also trying to plug in another shake (which we’ll call the “offline shake”) via ethernet to my computer and access the data directly that way without it being online. I have been able to connect to the offline shake no problem previous to me connecting the online shake to the network, and I can connect to my offline shake when I disconnect my computer from the internet. However, when I am connected to the internet, the online shake is the only one I can connect to (both at rs.local and through ssh).
The offline shake does not appear at rs-2.local (or any variation thereof). I was also hoping with the new dashboard would show the IP address of any additional shakes, but when I go there, it only shows the online shake.
I am on a work network and that sometimes throws things off (it also makes it hard to just connect a shake to the network…IT had to allow the other shake to connect), but I was having similar issues on my home network too.
For now, my workaround is just to disconnect my computer from the internet whenever I need to access the offline shake, but any thoughts about how to streamline this?
Thank you for your reply! I will see if I can do this.
The similar issue I am having at home is the additional shakes not showing up at rs-2.local, but I have not tried that since the new dashboard has been implemented, so I will give it another shot when I have the equipment at home next, and follow your instructions if there are still issues.
Hello rbalik, just checking in to see how things are going.
A couple of further details from our software team: the first regards rs.local/. For it to work with the -2, -3, and more suffixes, all Shakes have to share the same subnet. Otherwise, you will only see the Shake that is on the same network as the PC you are trying to access it from.
What you can do is fetch the IP address of the Shake connected via PC, and then access the Shake dashboard using that address in your browser bar, instead of rs.local/.
Thank you for following up! I have tested this a bit over the past month, and was able to get things working more or less both at home and work. As you suggest, it seems that whenever I am connected via the network, I cannot use rs.local (with prefixes, etc.) to connect via ethernet (without using the IP address directly). However, I was able to get the second shake connected to another network port (at home and at work) and the suffixes are working just fine. Thank you!
Great to read that at least with a different port the suffixes are working, rbalik. There must be some kind of specific network configuration that prevents the rs.local/ name from resolving properly.
