Hi There,
My Rshake has Problems connecting to the Server. In the beginning it did work perfectly.
Not any more. “No Connetion”
Even I can’t find the Station on your Map.
Logs are attached
Thanks!
Hi There,
Logs are attached
Thanks!
Hello Zetorshake, and welcome to our community!
Thank you for posting the logs from your Shake. It appears that communications were all right up until the start of this month and then stopped.
Could I please ask you to:
I would like to have freshly started Shake logs to compare with the logs you’ve just sent me.
Thank you!
Hallo Stormchaser,
ok, I have done that, here are the Fresh Logs
Hello Zetorshake,
Thank you for the new logs. They confirm what the first logs displayed as it appears that the instrument cannot find an internet connection, with these lines highlighting the issue:
2024 065 11:17:40: Unable to resolve hostname 'raspberryshake.net', most likely no DNS server available
2024 065 11:17:40: No internet connection found
2024 065 11:17:54: Unable to resolve hostname 'raspberryshake.net', most likely no DNS server available
Network Accessible : NO
As there are multiple set nameservers (gateways) in the Shake configuration, this seems a bit unusual, but it has happened before. I would recommend the following steps:
My first thought would be to check and see if the current power supply you are using is continuing to deliver a stable voltage between 5.0 and 5.2V and a current of at least 2.5A at all times, as a decrease in power could lead to data services interruption. If you have another Pi power supply that you know is in working condition, please try to exchange the current one with that, and see if the Shake now properly works for longer periods.
Try a different LAN cable (if you have one available) on all the modem/router ports, as this one may be the cause of the connectivity issue. Check that the cable is firmly inserted in the sockets.
Check the firewall settings of your modem/router to see if something software side could be blocking the connection. You should be able to find everything in the administration panel of your modem/router.
Also, it is possible that (some modem/router models do this) the ports necessary for the Shake to transmit data have been closed. You can check if the following ports Firewall issues? are closed, and reopen them if necessary.
Hi again,
thanks a lot for the support, we had to re-burn the image on the sd card.
It is now working well
Thanks!
Hello Zetorshake,
Happy to hear that, and glad that your Shake is now back on!
You’re welcome!
