The documentation says that using the wifi may introduce noise
https://manual.raspberryshake.org/wifi.html?highlight=wifi
I am wondering if this applies also to the case of the RS3D.
I suspect that it may not, because the RS3D uses the 3 external sensors instead of the MEMS.
Thanks
Hello konstantinos, and welcome to our community!
That particular warning applies to all our models, as WiFi-induced noise can be seen in their recorded traces when the onboard wireless module is turned ON.
This is why we recommend, if WiFi is required, to add an external dongle that manages to overcome this issue.
You’re more than welcome!
