I recently moved and my RS was not showing up on my new network. I decided to start from scratch, fully reformatted the SD card, loaded the RS operating system for gitlab. My router initially detected the RPi but with no IP address, but eventually it did obtain an address. There was no response to ping on the IP address or to Angry IP Scanner. When I plugged a monitor and keyboard, I saw a normal boot up screen, ending with a login request, which responded to the myshake user and correct password. It would come back with the station name and eventually with the IP address. BTW, the RS is connected directly to the router.
The installation README says: “Your Pi will now boot into NOOBS and should display a list of operating systems that you can choose to install.” This never happens–just the login.
I’m obviously missing something really obvious here, but I’m just not seeing it. As you might surmise, I’m pretty frustrated with this, especially since I’ve had it running previously for years and I have several other systems uploading data such as a PurpleAir, AIS tracker, ADS-B tracker, WX (weewx) and Sense (AC power monitor) all working well.
Stan Stone
MAC address:
B8:27:eb:f2:a9:93
Ping results:
ping: sendto: Host is down
Request timeout for icmp_seq 11
Request timeout for icmp_seq 12
Request timeout for icmp_seq 13
^[ping: sendto: Host is down
Request timeout for icmp_seq 14
Request timeout for icmp_seq 15
Request timeout for icmp_seq 16
Request timeout for icmp_seq 17
