Hi, some time ago I configured the raspberry station and after a period in which it was turned off, in the attempt to reconfigure it, it cannot connect to the server.
There should be no problems opening ports because I have not changed net line or router.
I attach the downloaded log, can you help me to understand the problem? Thank you very much.
RSH.R311C.2023-08-09T21_34_06.logs.tar (2.0 MB)
hello Saba,
the logs indicate very clearly that your unit is unable to make any connection with the internet whatsoever. in this case, NTP is unable to successfully start to set the Pi’s clock, and, it goes without saying, no connection to the Shake data server will be possible either.
since it is indeed getting an IP address assigned, i will conclude the router it’s connected to is available. in this case, you could try to log on to the router’s admin panel and see if you can deduce anything from there as to why the shake has no connection.
fyi: the log file postboot.log will tell you whether or not a connection to the internet is successful or not.
hope this helps,
