Just set up my Raspberry Shake (1D) using a Pi 3. It seemed to go through all of the proper startup and updating procedures (as near as I could tell from lots of flashing lights).
It appears to be stuck in “BOOTING”. (I have rebooted it). Also, no server connection.
Shake Model | : | Unknown model |
Raspberry Pi Model | : | 3 Model B |
System Status | : | BOOTING |
System Version | : | 0.20 |
Ethernet Local IPv4 | : | 192.168.1.162 |
Ethernet MAC | : | N/A |
Data Producer | : | OFF |
Data Consumer | : | OFF |
Off-line Mode | : | OFF |
Data Forwarding | : | ON |
Server Connection | : | Not Connected |
Latitude | : | 39.2030 |
Longitude | : | -120.0977 |
Elevation | : | 2000 m |
System Time | : | 2023-01-20 17:03:52 UTC |
Disk Usage | : | 22% Used – 11.4 Gb Available |
CPU Temp | : | 45 C / 113 F |
From MYSHAKE.OUT log file:
System Report: Fri Jan 20 17:10:15 UTC 2023
Versioning
OS Version : Raspbian GNU/Linux 10 (buster)
Kernel version : Linux raspberryshake 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l GNU/Linux
Software Version : v0.20
Firmware Version : unknown
ODF Version : unknown
Computer Info
/usr/local/bin/myShake: line 247: /opt/settings/sys/PI-version.txt: No such file or directory
RPi revision : (unknown)
/usr/local/bin/myShake: line 250: /opt/settings/sys/ODFSPNAME.txt: No such file or directory
ODF Serial Port :
MAC Address : b8:27:eb:85:bd:cb
UpTime : 17:10:15 up 8 min, 0 users, load average: 0.02, 0.21, 0.16
System time : Fri Jan 20 17:10:15 UTC 2023:
Disc usage : /dev/root 15G 3.0G 12G 21% /
CPU Temp : 44 C
System Info
heli_ewII : NOT Running
OWS : NOT Running
SeedLink : NOT Running
ODF : NOT Running
slarchive : NOT Running
SL info:
NONE Available
crontab Info:
@daily /usr/local/bin/myShake
@hourly /usr/local/bin/clean-logs
1 19 * * 1 /usr/local/bin/rsh-sw-fetcher C >/dev/null 2>&1
Station Info
Data-Sharing Mode : ON
Data Server Conn : OFF
Save Data Days : 7
Heli Scale : 0.5
cat: /opt/settings/sys/NET.txt: No such file or directory
cat: /opt/settings/sys/STN.txt: No such file or directory
cat: /opt/settings/sys/LOC.txt: No such file or directory
cat: /opt/settings/sys/CHN.disp.txt: No such file or directory
Station Name : …
Geophone : OSOP
