Networking and /etc/dcpcd.conf
New Shake, and I had the problems noted by several folks - addresses resolved, but was unable to contact hosts.
My router is a Netgear Orbi, and it doesn’t block ports. Chased several rabbit holes…
Found some sites that discussed /etc/dhcpd.conf. As now expected, the “static routers=” , which should have been the same as the domain_name_server, was empty. Adding the same IP address and restarting networking fixed it.
After editing the file, perform the following:
sudo systemctl daemon-reload
sudo systemctl stop dhcpcd.service
sudo systemctl start dhcpcd.service
sudo systemctl restart networking.service
Still don’t know why that happened - still more rabbit holes to dive into.
Kevin
Hello Kevin, and welcome to the community!
Thank you for reporting this. It is a known issue (as you have seen) and it will be fixed in the next Shake OS release.
Thank you for posting all the steps you’ve done, and apologies for the inconvenience.
