My RS4D (R9344) is no longer connecting. We changed the network to a static IP. I then logged onto the station webpage and under settings->Network-> I checked Static IP and put the IP in there and then rebooted. This broke the Shake. I then directly connected to the Shake and unchecked static IP and rebooted but I can no longer connect to the Shake. Is there anything I need to do to allow it to connect and send data?
Hello fishynp, and welcome to the community!
I think I may know what is causing this issue. Could you please connect directly again, then log into the Shake via SSH (if needed, instructions on how to do so can be found here: How to access your Raspberry Shake’s computer via ssh ), run the following two commands:
cat /etc/dhcpcd.conf
cat /etc/resolv.conf
and post their output here? Thank you!
myshake@raspberryshake**:/opt $ cat /etc/dhcpcd.conf
interface eth0
static domain_name_servers=172.20.120.20
static ip_address=155.97.106.153/
static routers=
#controlgroup wheel
clientid
or
#duid
persistent
Rapid commit support.
option rapid_commit
option ntp_servers
Respect the network MTU.
#option interface_mtu
slaac private
#nohook loo
Thank you fishynp, this is just what I needed.
The first lines confirm the idea I had in mind. On some occasions, due to a known bug (that will be fixed in the coming Shake OS releases), no specified static router appears in the dhcpcd.conf
, and the Shake cannot find the proper gateway to reach the wider internet.
To fix this, open the file again with:
sudo nano /etc/dhcpcd.conf
Then delete all the lines starting with static
static routers=
And leave only interface eth0
at the start of the file. Then, save the file with the sequence:
Ctrl+X
, Y
, Enter
To make sure those changes took hold, restart the service with:
sudo service dhcpcd restart
And, lastly, restart the shake with sudo reboot
Now, your Shake should be able to connect via your router. If you want to configure a Static IP again, you’ll have to do it manually, following a similar procedure. You can find detailed instructions here: Static IP.
If other issues arise, plase download the new log files, copy the new output from the dhcpcd and resolv files, and post all here.
That fixed it! It’s back up and running. Thanks.
Great to read that, happy to help!
