I’m using the app on an Android phone and have had numerous issues.
EVENTS. The distances listed for EQs have no relation to my location. When I open the STATIONS tab, the map is centered on London, and I suspect the distances are measured from there. Clearly the distances are listed because they are intended to be meaningful,so how do I make the distances meaningful to me?
MY STATIONS. Thinking issue (1) might be because I own and operate three shakes, I selected one to follow, but it made no difference to the listed event distances. Foolishly I then chose to follow my other two Shakes and found all three of my Shakes had disappeared from the My Shakes list and were instead listed under “Following”. Unfollowing them removed them from the Following list, but they initially didn’t reappear in the My Stations list. After some time, they did reappear, but I’m not sure if it is necessary to exit the app before they reappear or just a matter of waiting tens of minutes.
MY STATIONS. Of my three Shakes, one has had three different names due to loss of the ethernet port then a later change to a new Pi. How can I remove these “offline” stations from the list.
24-HR PLOT. When I highlight an event to see the event in detail with the frequency plot, then return (using the top left “<”) to view another of My Stations with the 24-hour plot, the app crashes and closes. To stop this happening, the magnified trace and frequency plot must be swiped off the bottom of the screen before pressing the “<” at the top left of the screen. Same applies to the “<” at the bottom right.
It would be nice to have a manual that covered all aspects of the app (and I’m prepared to be embarrassed in being told there is a clearly labelled link to such a manual).
