My RS&B appears not to be recognized by swarm (see attached photo). Instructions tell you to click the “+” next to all, to find the specific device - but this is not an option in my case.
Note: I am able to find other stations through RSCommunity>All>etc. as expected.!
Thank you for your help! It is indeed now detected by SWARM. However, when I try to select the Raspberry shake it appears not to load properly (see below)
When the Shake code/channels are greyed out like that it means that there has been an issue where SWARM cannot connect to the Shake itself.
Please crosscheck that the IP address is the correct one, and if it is, shut down your Shake and reboot your modem/router. When internet is available again, then restart your Shake, check if the IP address is the same as before or if it has changed, and start SWARM again (inserting the new IP if needed).
If this doesn’t work then I can suggest downloading and try with the latest version of SWARM (v3.2.0) available here: USGS: Volcano Hazards Program
