Hello, I was able to create a text post, but when I press Upload, at the bottom of the form, it immediately goes to “Uploading 100%”, then get a popup stating “Sorry, there was an error uploading 240808-IMG_0803.jpg. Please try again.”
I tried this on both an iPad and a Windows 10 PC running Firefox v129 (64 bit), both with the same results.  The file size is 633Kb.  Also, the picture was a screen capture with my iPad (if it makes a difference).  Jim, AM.R907E
              Hello Jim,
We have asked our team to check on this, as that’s an error that should not happen, especially with a file that small in size.
Apologies for the issue. I’ll update you as soon as I have news.
In the meanwhile, you can use services such as imgur (http://imgur.com/) or similar to upload the image there and then link it here in your reply.
              Thanks.   I appreciate all things you guys do!  Jim
              Hello again Jim,
The image upload should have been restored.
You should now be able to add pictures in your messages as before.
Thank you again for the notification!
              Thanks, and image uploaded!  Jim
