My RS4D just dropped off the network again. I was trying to establish a static IP address, and something went wrong. Now the Log Files indicated I don’t have NTP because the RS can’t access the internet. I can get a (delayed) helicorder display but nothing else (via Swarm).
The lesson learned here is, if it is not broken, don’t fix it. Leave it alone.
Here are my Data Logs.
RSH.R29F6.2024-05-27T21_40_18.logs.tar (3.0 MB)
Hello Gary, welcome back to the community and thank you for the logs!
Indeed, the Shake boots up without issues, as you have seen, but it cannot seem to find a proper network connection:
2024 148 21:24:07: Network detection failed, unable to curl or ping common sites
2024 148 21:24:07: No internet connection found
Could I please ask you to SSH into the Shake (instructions on how to do so can be found here: How to access your Raspberry Shake’s computer via ssh) and execute the following two commands?
cat /etc/dhcpcd.conf
cat /etc/resolv.conf
Then copy/paste their output here? Thank you!
But I have switched it over to wireless operation and it is working fine.
Didn’t have to do any SH -ing.
Gary
Happy to hear that Gary!
If you need anything else, you know where to find us.
