I am currently working on a research project looking to use RaspberryShakes as stand-alone sensors, possibly in an environment without an internet connection.
I have been using SWARM for the past few months, but I would like to be able to directly view and manipulate a .csv file. I was wondering if there is a way to convert miniSEED files to CSV/text, and where these daily log files would be stored if the Raspberry Pi was not connected to the internet.
Thanks for your patience and help; I’ve been stuck on this for a while now.
It converts miniSEED format into ASCII, and from that, I think you can import it into a .csv file. Maybe it will need some adjustments, but I think it is worth a try.
Another method that you can try is to combine the UDP DATACAST stream from the Shake to a python process running on the Shake itself that you can write to transform and write the ASCII data to a .csv format file directly.
Also, there is already a program on the Shake-Pi (directory /opt/settings/user) that will do the connection and data-stream setup for the user. This program could be tweaked/enhanced to output the data to another file in the user’s preferred format, such as the .csv that you require.
In the end, a bit of tinkering and trial-and-error could be what you need to properly obtain the data format that you need.
