Tropical storm / hurricane Henri was not a very big one but it was big enough to see on the RBoom - first one of the season that registered here.
showing the day before and the day after it passed by
distance involved
distance involved
Hello kpjamro, that’s a clear and great recording!
I was following Henri through a Shake&Boom near Boston, a bit closer to the approach track, and it got the entire transit quite well:
Also, another S&B in Mexico City managed to capture the weakening Hurricane Grace there too:
Thank you for sharing your data with us! Now that the hurricane season is underway, we may get similar tracks from other stations in our network.
To be clear - this is not the wind from the storm but rather an atmospheric disturbance set up by waves at sea. The only way for me to see the characteristic 0.25 Hz +/- signal is when it is dead quiet here - essentially zero wind velocity. The helicorder graph appears nearly a flat line, as the signal being looked for is quite weak - just above the noise floor of the RBoom electronics. This “bump” in the circle is it -
