I’m trying to get the metadata file, station.xml,from the shake itself, but i can’t find the file, is it possible, or is it only possible with the Data forwarding option enabled?
Hola Pablo:
The complementary service of automatically building and maintaining inventory xml metadata files is only available when you share the data.
You can use the templates here to build your own: http://manual.raspberryshake.org/metadata.html#metadata
Yours, branden
