I noticed that there is a slight mismatch between the location coordinates defined on the device and the shakenet view.
is showing local configuration vs shakenet
A similar discrepancy is displayed on the map. I understood that the device configuration defines whe shakenet data, so I would have assumed both data should be the same?
