Hello, I have some issues with my RBOOM, its connected to the network and I can RSH to it, ping it etc but it does not appear to connect to the server or send much data, I have the logs but don’t know how to read them. I am using RSUDP on a server on the same network and it doesn’t seem to connect although setup to connect. This all used to work flawlessly up until about a month or so ago, even though nothing really has changed.
SLarchive log:
Fri Jun 10 02:15:55 2022 - network timeout (900s), reconnecting in 30s
Fri Jun 10 02:31:26 2022 - network timeout (900s), reconnecting in 30s
Fri Jun 10 02:46:57 2022 - network timeout (900s), reconnecting in 30s
Fri Jun 10 03:02:27 2022 - network timeout (900s), reconnecting in 30s
Fri Jun 10 03:17:58 2022 - network timeout (900s), reconnecting in 30s
Fri Jun 10 03:33:29 2022 - network timeout (900s), reconnecting in 30s
Fri Jun 10 03:49:00 2022 - network timeout (900s), reconnecting in 30s
Fri Jun 10 04:04:30 2022 - network timeout (900s), reconnecting in 30s
odf_SL_plugin_warn:
| 2022 160 04:30:15>> | DP send to DDS server failed, cannot requeue, queue is full (369865 messages) |
| 2022 160 04:33:39>> | DP send to DDS server failed, cannot requeue, queue is full (369865 messages) |
| 2022 160 04:34:17>> | DP send to DDS server failed, cannot requeue, queue is full (369864 messages) |
| 2022 160 04:35:07>> | DP send to DDS server failed, cannot requeue, queue is full (369863 messages) |
| 2022 160 04:35:27>> | DP send to DDS server failed, cannot requeue, queue is full (369862 messages) |
| 2022 160 04:38:36>> | DP send to DDS server failed, cannot requeue, queue is full (369861 messages) |
| 2022 160 04:39:00>> | DP send to DDS server failed, cannot requeue, queue is full (369860 messages) |
| 2022 160 04:39:25>> | DP send to DDS server failed, cannot requeue, queue is full (369859 messages) |
| 2022 160 04:42:47>> | DP send to DDS server failed, cannot requeue, queue is full (369858 messages) |
| 2022 160 04:43:15>> | DP send to DDS server failed, cannot requeue, queue is full (369858 messages) |
| 2022 160 04:44:03>> | DP send to DDS server failed, cannot requeue, queue is full (369857 messages) |
odf_sl_plugin.err:
2022 161 04:17:52>> ! Q
2022 161 04:17:52>> 1ÑãWDDI–àe†AgMźOkàM&ÑQ’TI I]ä’ïU’QA
2022 161 04:17:52>> 16370 27
2022 161 04:17:58>> internal error: buffer overflow! cannot process read data…
2022 161 04:17:58>> buf:
2022 161 04:17:58>> X†ÅÑEúJ]ä‰L]™
2022 161 04:17:58>> AA∫EBaÉa‡FE
2022 161 04:17:58>> Yàîà ‘U≤U
2022 161 04:17:58>> Yàîc†cTBSTBeî…∆‚ÅEIIãULÅEî…ÀLDI …ÀëeEBeîŸ F
2022 161 04:17:58>> äW†ë[EBWeëE—DŸgEBeURW‚ÅUUUIE´Q—ëEúÅUMUIH´Uõ
2022 161 04:17:58>> 5U†¡SãU™Y!ÅE%ÅSÅRUlÅU!UI¿àE
2022 161 04:17:58>> Y.îò™eíBUã
2022 161 04:17:58>> çHYòE
2022 161 04:17:58>> *%— AÜFEY Ÿ AòDB[ùëE´$ÅWàED™eî…√—ÅEî…À,
2022 161 04:17:58>> 16370 27
2022 161 04:18:05>> internal error: buffer overflow! cannot process read data…
2022 161 04:18:05>> buf: ÅEî… ñe†— AÜFIY Ÿ ÅUíBeîô∆A
2022 161 04:18:05>> Yàîg†¡ÀQWEBeîŸ∂ÃP
2022 161 04:18:05>> YàîVS†¡ÀQÜeTI0…À1äUBeî…∑eëEî…À6%¡ QUHI … ±SUBeî…∆!ÅEî… ïEI … ëQÇReî…∆U
2022 161 04:18:05>> YàîÑU†—nîc†¡ÀQñïTI0…À1SÇBeî…≥‚ëEî…À!TI0…À
2022 161 04:18:05>> 16362 27
2022 161 04:18:11>> internal error: buffer overflow! cannot process read data…
2022 161 04:18:11>> buf: 'DI I]™’îE’AA0JE
2022 161 04:18:11>> X†ÅÑEúJ]ä‰L]™
2022 161 04:18:11>> AA∫EBaÉa–â∆‘U÷™W\FY–ÿU†AaïëEIU
2022 161 04:18:11>> E«+]– U†AaúÅE!EE
2022 161 04:18:11>> !HU
2022 161 04:18:11>> !≈U
2022 161 04:18:11>> !U
2022 161 04:18:11>> !ÑE
2022 161 04:18:11>> 1I™WDHI–à[†AcLÅE1≈E
2022 161 04:18:11>> !D´WDDI–âe†ëQE
2022 161 04:18:11>> QãU Y†ÅQ
2022 161 04:18:11>> SÇBQ´%Ae’ÅEEE
2022 161 04:18:11>> 5SÅBWåDI– [†AcÑÅEƒãW¬FI– S†Ae
2022 161 04:18:11>> EEWÚII–IW†AaçÅE!∆E
2022 161 04:18:11>> [UBQª%AeTÅEED™Q™$ëSLÅUUEºOkàM∏≤ÑQ’TI I]ä’ïU’QA
2022 161 04:18:11>> 16377 27
I am wondering if this is a local UDP issue as TCP seems to be fine…
I will use rs-packetloss on rsudp machine to monitor what’s happening and report back.
just seen this in the odf_SL_plugin.err log:
This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:13>> sendDClientDP(): Error sending data …
2022 161 05:17:13>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:13>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:14>> sendDClientDP(): Error sending data …
2022 161 05:17:14>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:14>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:15>> sendDClientDP(): Error sending data …
2022 161 05:17:15>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:15>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:16>> sendDClientDP(): Error sending data …
2022 161 05:17:16>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:16>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:17>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:17>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:17>> Connection request (raspberryshakedata.com:55555) failed with error code: Connection refused
2022 161 05:17:17>> sendDClientDP(): Error sending data …
2022 161 05:17:18>> sendDClientDP(): Error sending data …
2022 161 05:17:18>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:18>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:18>> internal error: buffer overflow! cannot process read data…
2022 161 05:17:18>> buf: {ˇOk®\u≥âS27Q†ÅÀîQ–E
2022 161 05:17:18>> 'QA
2022 161 05:17:18>> 16224 229
2022 161 05:17:19>> sendDClientDP(): Error sending data …
2022 161 05:17:19>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:19>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:20>> sendDClientDP(): Error sending data …
2022 161 05:17:20>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:20>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:21>> sendDClientDP(): Error sending data …
2022 161 05:17:21>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:21>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:22>> sendDClientDP(): Error sending data …
2022 161 05:17:22>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:22>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:23>> sendDClientDP(): Error sending data …
2022 161 05:17:23>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:23>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:24>> sendDClientDP(): Error sending data …
2022 161 05:17:24>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:24>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:25>> sendDClientDP(): Error sending data …
2022 161 05:17:25>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:25>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:26>> sendDClientDP(): Error sending data …
2022 161 05:17:26>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:26>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:26>> internal error: buffer overflow! cannot process read data…
2022 161 05:17:26>> buf: E
2022 161 05:17:26>> åE
2022 161 05:17:26>> ‘ÅRSª$g»
2022 161 05:17:26>> YäD e†Yª
2022 161 05:17:26>> UUBU $AUMźOk3I] ûUª%ëŒÑA˙ˇOkà
2022 161 05:17:26>> ]∏¢ÑQ˛E
2022 161 05:17:26>> Y†ÅMäîK]ä+ïEúAAÎúJ]ä‰,Y‡ÑEAA∫EBaɇ…U†ëaåÅEeE
2022 161 05:17:26>> W™TW†AQ’ëEcURWeÇBW“FI‡W†ÅWúÅEÖ E
2022 161 05:17:26>> äYUBS$Åe∏
2022 161 05:17:26>> T§+\‡[†Ac“ëE¡™WïUI–U†QYe†A„âE
2022 161 05:17:26>> UTBQe%ÅeïÅEç™QçHI–I™‘U¡X™W¡EY¿U†Ae+
2022 161 05:17:26>> 5¨ëBWïTI–â´‘UMôE
2022 161 05:17:26>> 5aURQUH’ÅS
2022 161 05:17:26>> TWëBWåVI–Öß‘U—™UII¿H¶‘E1E
2022 161 05:17:26>> ÒÑ´WúII‡D´Ù‹Ok®M®≤îQ’TY Y]ä’îU’QA
2022 161 05:17:26>> 16329 269
2022 161 05:17:27>> sendDClientDP(): Error sending data …
2022 161 05:17:27>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2022 161 05:17:27>> Data has been successfully received, fatal condition resolved.
2022 161 05:17:27>> Connection request (raspberryshakedata.com:55555) failed with error code: Connection refused
here is the system report:
System Report: Fri Jun 10 05:17:24 UTC 2022
Versioning
OS Version : Raspbian GNU/Linux 10 (buster)
Kernel version : Linux raspberryshake 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
Software Version : v0.20
Firmware Version : RSnB-5-4.10
ODF Version : 2020.045
Computer Info
RPi revision : a020d3 (3 Model B+)
ODF Serial Port : /dev/ttyS0
MAC Address : b8:27:eb:8f:9f:0d
UpTime : 05:17:24 up 15:20, 1 user, load average: 0.21, 0.14, 0.14
System time : Fri Jun 10 05:17:24 UTC 2022:
Disc usage : /dev/root 7.4G 3.9G 3.3G 54% /
CPU Temp : 79 C
System Info
heli_ewII : Running
OWS : Running
SeedLink : Running
ODF : Running
slarchive : Running
SL info:
AM R9F0D 00 EHZ D 2022/06/09 14:01:46.6890 - 2022/06/10 05:07:22.7540
AM R9F0D 00 HDF D 2022/06/09 14:01:46.6890 - 2022/06/10 05:07:23.1340
crontab Info:
@daily /usr/local/bin/myShake
@hourly /usr/local/bin/clean-logs
10 15 * * 5 /usr/local/bin/rsh-sw-fetcher C >/dev/null 2>&1
Station Info
Data-Sharing Mode : ON
Data Server Conn : ON
Save Data Days : 7
Heli Scale : 0.5
Station Name : AM.R9F0D.00.[EHZ][HDF]
Geophone : OSOP
Clock Info
- ntpdate.service - Network Time Service
Loaded: loaded (/lib/systemd/system/ntpdate.service; enabled; vendor preset: enabled)
Active: active (exited) since Thu 2022-06-09 13:57:54 UTC; 15h ago
Process: 2350 ExecStart=/usr/sbin/ntpd -u ntp:ntp -q -g -x -t 5 (code=exited, status=0/SUCCESS)
Jun 09 13:57:47 raspberryshake ntpd[2350]: Listen and drop on 1 v4wildcard 0.0.0.0:123
Jun 09 13:57:47 raspberryshake ntpd[2350]: Listen normally on 2 lo 127.0.0.1:123
Jun 09 13:57:47 raspberryshake ntpd[2350]: Listen normally on 3 eth0 192.168.1.193:123
Jun 09 13:57:47 raspberryshake ntpd[2350]: Listen normally on 4 docker0 172.17.0.2:123
Jun 09 13:57:47 raspberryshake ntpd[2350]: Listen normally on 5 veth0a278ab 169.254.213.208:123
Jun 09 13:57:47 raspberryshake ntpd[2350]: Listening on routing socket on fd #22 for interface updates
Jun 09 13:57:54 raspberryshake ntpd[2350]: ntpd: time slew -0.034650 s
Jun 09 13:57:54 raspberryshake ntpd[2350]: 9 Jun 13:57:54 ntpd[2350]: ntpd: time slew -0.034650 s
Jun 09 13:57:54 raspberryshake ntpd[2350]: ntpd: time slew -0.034650s
Jun 09 13:57:54 raspberryshake systemd[1]: Started Network Time Service.
- ntpd.service - Network Time Service
Loaded: loaded (/lib/systemd/system/ntpd.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2022-06-09 13:57:55 UTC; 15h ago
Process: 3508 ExecStart=/usr/sbin/ntpd -u ntp:ntp -f /etc/ntp.conf -p /run/ntpd.pid (code=exited, status=0/SUCCESS)
Main PID: 3510 (ntpd)
Tasks: 2 (limit: 2059)
CGroup: /system.slice/ntpd.service
`-3510 /usr/sbin/ntpd -u ntp:ntp -f /etc/ntp.conf -p /run/ntpd.pid
Jun 10 04:59:06 raspberryshake ntpd[3510]: new interface(s) found: waking up resolver
Jun 10 05:00:42 raspberryshake ntpd[3510]: Deleting interface #22 eth0, 192.168.1.193#123, interface stats: received=3, sent=3, dropped=0, active_time=96 secs
Jun 10 05:00:42 raspberryshake ntpd[3510]: 162.159.200.123 local addr 192.168.1.193 ->
Jun 10 05:00:42 raspberryshake ntpd[3510]: 178.128.28.21 local addr 192.168.1.193 ->
Jun 10 05:00:42 raspberryshake ntpd[3510]: 203.123.48.219 local addr 192.168.1.193 ->
Jun 10 05:00:53 raspberryshake ntpd[3510]: Listen normally on 23 eth0 192.168.1.193:123
Jun 10 05:00:53 raspberryshake ntpd[3510]: 203.123.48.219 local addr 169.254.213.208 -> 192.168.1.193
Jun 10 05:00:53 raspberryshake ntpd[3510]: 178.128.28.21 local addr 169.254.213.208 -> 192.168.1.193
Jun 10 05:00:53 raspberryshake ntpd[3510]: 162.159.200.123 local addr 169.254.213.208 -> 192.168.1.193
Jun 10 05:00:53 raspberryshake ntpd[3510]: new interface(s) found: waking up resolver
+time.cloudflare 10.23.8.4 3 u 256 1024 1 49.575 -47.954 4.293
*178.128.28.21 218.186.3.36 2 u 260 1024 1 44.466 -54.037 9.964
+ntpmon.dcs1.biz 218.186.3.36 2 u 59 1024 7 39.075 -18.781 5.319
Network Info
Stand-Alone Mode : OFF
Ethernet UP : YES
WiFi UP : YES
DNS Available : YES
Network Accessible : YES
Nameservers : 192.168.1.254
=== Shake Data Server ===
/usr/local/bin/myShake: line 396: NO: command not found
Port 55555 :
Port 55556 : YES
=== ifconfig =======
docker0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.17.0.2 netmask 255.255.0.0 broadcast 0.0.0.0
ether 02:42:6a:6e:39:6e txqueuelen 0 (Ethernet)
RX packets 102391 bytes 38249947 (36.4 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 67679 bytes 10499560 (10.0 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.193 netmask 255.255.255.0 broadcast 192.168.1.255
ether b8:27:eb:8f:9f:0d txqueuelen 1000 (Ethernet)
RX packets 481732 bytes 99262711 (94.6 MiB)
RX errors 0 dropped 1 overruns 0 frame 0
TX packets 48906 bytes 28643926 (27.3 MiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1000 (Local Loopback)
RX packets 257 bytes 38166 (37.2 KiB)
TX packets 257 bytes 38166 (37.2 KiB)
veth2205165: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 169.254.206.76 netmask 255.255.0.0 broadcast 169.254.255.255
ether c2:71:27:75:3d:63 txqueuelen 0 (Ethernet)
RX packets 7530 bytes 472878 (461.7 KiB)
TX packets 8267 bytes 2637920 (2.5 MiB)
veth0175f19: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 169.254.172.102 netmask 255.255.0.0 broadcast 169.254.255.255
ether ce:b9:a8:62:63:3b txqueuelen 0 (Ethernet)
RX packets 72114 bytes 19846820 (18.9 MiB)
TX packets 40116 bytes 6390500 (6.0 MiB)
veth0a278ab: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 169.254.213.208 netmask 255.255.0.0 broadcast 169.254.255.255
ether f6:5f:65:26:e8:7b txqueuelen 0 (Ethernet)
RX packets 22722 bytes 19361341 (18.4 MiB)
TX packets 23744 bytes 2751866 (2.6 MiB)
===== END ========
=== /etc/network/interfaces FILE ==========
interfaces(5) file used by ifup(8) and ifdown(8)
Please note that this file is written to be used with dhcpcd
For static IP, consult /etc/dhcpcd.conf and ‘man dhcpcd.conf’
Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
Start wlan0 definition
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
===== END ========
WiFi Info
Kernel modules loaded : NO
Enablement : OFF
Bluetooth Info
Kernel modules loaded : YES
State : active
Enablement : disabled
Docker Info
Docker version 1.11.1, build 5604cbe
IMAGE ID CREATED AT SIZE REPOSITORY
93374cd693bd 2021-09-17 20:39:31 +0000 UTC 95.46 MB registry.gitlab.com/rshake-public/rsh-fe-config
7b20e90e6a6a 2020-02-14 13:25:56 +0000 UTC 159.5 MB registry.gitlab.com/rshake-public/rsh-data-producer
79f3943a55c6 2019-01-30 19:16:42 +0000 UTC 140.8 MB registry.gitlab.com/rshake-public/rsh-fe-config
992d3d7c940f 2017-06-10 16:40:10 +0000 UTC 144.8 MB registry.gitlab.com/rshake-public/rsh-data-consumer
CONTAINER STATUS CREATED AT
registry.gitlab.com/rshake-public/rsh-data-consumer Up 15 hours 2022-06-09 13:58:02 +0000 UTC
registry.gitlab.com/rshake-public/rsh-data-producer Up 15 hours 2022-06-09 13:57:59 +0000 UTC
registry.gitlab.com/rshake-public/rsh-fe-config:v19 Up 15 hours 2022-06-09 13:56:58 +0000 UTC
Hello clubber1966,
Thak you for contacting us about this issue that you are experiencing.
It appears to be some kind of communication problem, however, without the full logs, I cannot be sure of it. Could you please download all the logs from the /opt/log folder inside the Shake, zip them, and attach them to your answer here on the forum?
Or, in an easier way, if you can access your Shake via IP address or rs.local/, can you please download the zip file from the orange button at the end of the main page, and attach it?
here you go…RSH.R9F0D.2022-06-10T05_17_27.logs.tar (4.2 MB)
Hello clubber,
Thank you for the complete logs. From them, it appears that there have been some connection problems, but not dependent on the Shake (most likely from your local internet).
However, now they seem to have been solved, because I can see your unit live streaming data to our services, here: RS StationView
If you need anything else in the future, I remain available.
for what it is worth, I had to login via ssh to my Shake and Boom and noticed that the docker images were not loading and when they did a route out via eth0 default gateway was not properly setup, they docker seems to setup a docker default route of default dev veth8dc662f scope link src 169.254.231.59 metric 213
Also if the wifi is loaded as well as the ethernet connection it can cause lots of issues with boom communicating.
whereas the eth0 default gateway doesn’t get setup. Has to be a sequence of booting that causes the booms to go offline. after running a default route and restarting the containers it came back in
hope it helps someone
Hello James, and welcome back to the community.
Thank you so much for your feedback and extended description of what the situation was and how you solved it.
Do you have any logs of before you fixed the issue? No problem if not, but if you do, can you please share them with us, as they could provide very useful insight?
Thank you in any case!
Hi There,
My Rs&B randomly deletes the default gateway. dmesg shows
[ 5.553329] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.559203] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.559800] usbcore: registered new interface driver brcmfmac
[ 5.788624] random: crng init done
[ 5.788638] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.811568] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.824783] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 6.465545] 8021q: 802.1Q VLAN Support v1.8
[ 6.636774] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 7.071216] 8021q: adding VLAN 0 to HW filter on device eth0
[ 19.019914] capability: warning: `zerotier-one’ uses 32-bit capabilities (legacy support in use)
[ 19.644537] tun: Universal TUN/TAP device driver, 1.6
[ 23.002056] NET: Registered protocol family 10
[ 23.006765] Segment Routing with IPv6
[ 23.030395] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 23.036839] Bridge firewalling registered
[ 26.023926] docker0: port 1(veth57c6f75) entered blocking state
[ 26.023942] docker0: port 1(veth57c6f75) entered disabled state
[ 26.024467] device veth57c6f75 entered promiscuous mode
[ 26.163980] IPv6: ADDRCONF(NETDEV_CHANGE): veth2148dd7: link becomes ready
[ 26.164179] IPv6: ADDRCONF(NETDEV_CHANGE): veth57c6f75: link becomes ready
[ 26.164264] docker0: port 1(veth57c6f75) entered blocking state
[ 26.164274] docker0: port 1(veth57c6f75) entered forwarding state
[ 26.164409] IPv6: ADDRCONF(NETDEV_CHANGE): docker0: link becomes ready
[ 28.407504] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
[ 28.613194] docker0: port 1(veth57c6f75) entered disabled state
[ 28.614311] eth0: renamed from veth2148dd7
[ 28.673941] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 28.674157] docker0: port 1(veth57c6f75) entered blocking state
[ 28.674168] docker0: port 1(veth57c6f75) entered forwarding state
ip r
\default dev veth57c6f75 scope link src 169.254.253.29 metric 207
10.147.21.0/24 dev ztyvk53xzz proto kernel scope link src 10.147.21.59
169.254.0.0/16 dev veth57c6f75 scope link src 169.254.253.29 metric 207
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.2
192.168.1.0/24 dev eth0 proto dhcp scope link src 192.168.1.28 metric 202
└──╼ $sudo route add default gw 192.168.1.1 eth0
some times when I issue a
sudo docker restart $(docker ps -q) to start all containers after adding the default gateway route, it comes back.
happy to send the logs
Postboot shows
2024 038 04:15:15: adding fallback DNS servers to /etc/resolv.conf file
2024 038 04:15:29: Unable to resolve hostname ‘raspberryshake.net’, most likely no DNS server available
2024 038 04:15:29: No internet connection found
2024 038 04:15:43: Unable to resolve hostname ‘raspberryshake.net’, most likely no DNS server available
2024 038 04:16:01: Unable to resolve hostname ‘raspberryshake.net’, most likely no DNS server available
2024 038 04:16:18: Unable to resolve hostname ‘raspberryshake.net’, most likely no DNS server available
2024 038 04:16:35: Unable to resolve hostname ‘raspberryshake.net’, most likely no DNS server available
2024 038 04:16:46: NTP failed to start, and we have an interent connection, trying to restart it…
Producer shows an error of
Writing configuration for diskmon
2024 038 04:18:11: Starting Seiscomp
find: `/opt/seedlink/acquisition/seedlink/RB8A3’: No such file or directory
SeisComP version 2.6 (2009.075)
starting seedlink
starting client slarchive 127.0.0.1:18000
enabling diskspace monitoring
the changing dns servers could be the issue as it will not be compatible with my starlink DNS
Thank you so much for getting back with these logs James, and for the further details about the issue.
I’ll pass everything on to our software team; they’ll be happy to have these at hand.
We know that Starlink DNS may require specific configurations, and other users have had to work around a bit to get everything “on track” with that equipment: Install failure, v.20 [understood: it is the Starlink router]
I read that but it doesn’t account for why it intermittently stops routing the default route and reverts back to the docker 169 route, something not correct in your modiules.
8:16 SIngapore time for no reason lost the default route once again to my gateway to the internet. caught this in dmesg
[525294.475677] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=1b64067dba4f8d1225a169e702759f6006a430a2c71ee13e054babe773ac0a0d,mems_allowed=0,global_oom,task_memcg=/,task=odf_SL_plugin,pid=13085,uid=0
[525294.475747] Out of memory: Killed process 13085 (odf_SL_plugin) total-vm:619176kB, anon-rss:557640kB, file-rss:0kB, shmem-rss:0kB, UID:0 pgtables:576kB oom_score_adj:0
[525294.644804] oom_reaper: reaped process 13085 (odf_SL_plugin), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
[531599.007158] docker0: port 3(veth5a8c6f6) entered disabled state
Ok the going offline is linked to:
[844051.849668] Out of memory: Killed process 553 (odf_SL_plugin) total-vm:353072kB, anon-rss:291880kB, file-rss:0kB, shmem-rss:0kB, UID:0 pgtables:320kB oom_score_adj:0
[844051.898881] oom_reaper: reaped process 553 (odf_SL_plugin), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
some insight into how to fix this would be great as this expensive product has been pretty much unusable from day one
Hello James,
with all these errors (particularly, the last Out of memory one appears quite unusual), I think that it may be worth resetting the Shake system and starting from scratch.
If you haven’t already, could you please re-burn the Shake OS image on the microSD card? Or, if you have already tried, can you try with a different microSD card?
If needed, instructions on how to do so are here: microSD card topics
With this, especially if you change the microSD card, we’ll make sure that all these errors (if they appear again) were not due to corrupted files or a microSD card that stopped working correctly. If they disappear, and the Shake starts working nominally again, then we can move forward to setting it up for your local network, as you have in mind.
If, instead, the errors are still there, and the Shake continues not to work, please download the logs once again and post them here, so that I can have another look.
I will get time over the next few weeks to start again with a new image and repirt back.
Thanks
No problem at all James, we’ll be here.
After rebuilding my SB nd connecting to wifi over my starlink it appears to be back online.
