This shake (R9C87) was previously online and working until I moved it to a new location (nearby). It seems to be working correctly internally (I can get charts etc) and connected to rs.local via Cat6 cable to home router, but reports “Server Connection: Not Connected” even after more than 24hr of operation. Does not appear on ShakeNet. Log files attached:
Thank you for the logs that you have provided. Nothing wrong appears to be present in them, and the Shake boots up as it should without issues.
Could you please reboot the Shake and then try the following procedure to see if it solves the connectivity issue?
The box was already checked, but I unchecked it, then checked it again and hit restart. Now it reports as connected, great! I’ll give it some time to see if it appears on ShakeNet again.
It seems to be reporting data to the server now, but there are gaps. Internet here has been troublesome recently. I’ve noticed others have had the gap problem for various reasons. I don’t see the gaps in my internal charts, so it’s a communication or maybe timing problem. I’ll post a separate thread on that when I next get some time to troubleshoot.
