Hello! I’ve noticed something quite interesting with my shake, while playing around with various locations of it. Interestingly enough, sometimes, the shake gets all the way down to 100 - 200 µm/s2, however, when restarting the shake for any number of reasons, in the same location, it seems to go up to around 500 - 600+ µm/s2 and does have a lot more visible noise. Surprisingly (to my delight) after bringing it inside for the day, setting it in its usual spot, the noise dropped a loot, down to 100 µm/s2 on average, compared to the usual 600+ I get in this exact same spot usually. Does anybody know why this could be? Thanks!
Hello noobaget,
Quite interesting! I’ve never paid attention to this trend when I was testing different locations around the house. I’ve simply observed which places were “noisier” compared to others…
Is it something you have observed every time you’ve restarted the Shake? That is, in the same location, the freshly restarted unit displays high values and then, gradually, goes down to quieter numbers?
Do you have a data sample (maybe a day/time reference on DataView) that I can take a look at?
Thank you!
