How can i enable port forwarding? or if its already enabled, how am i going to see the port number.
Thank you
Thank you
Hello waw0102,
Do you mean our UDP data forwarding to other computers in the same network as the Shake? In that case, you can check this manual page for all the details: Raspberry Shake Data Producer UDP Port Output
If not, can you describe in more detail what you have in mind so I can offer more defined help?
Thank you!
