Moved my RS3D inside from the greenhouse to the basement for the winter on ?October 16th, and I cannot get it to restart. Upon rebooting, sometimes “Producer” does not create data (see attached log) and other times, it gets stuck “rebooting”. Any thoughts?
hello MRT1953,
after looking at the log files, all signs point to the SD card being corrupted, which, in turn, is preventing the data-producer program from successfully starting.
please arrange a new SD card and burn it with the latest Shake-OS image:
- Format it before burning the new Shake OS image
and then let us know whether or not this resolves your issue.
Richard, thank you for your prompt and comprehensive response. As a septuagenarian, I haven’t a clue what that all means, so I found my second spare card when I last ordered two new cards to keep my RS3D running back in February 2022, changed out the corrupted card, and restarted the device. It’s now running Version 0.19 on 2022-02-24, but hasn’t created any viewable traces yet. If I can’t find a tech-savvy young person to assist me, I guess I’ll buy two more from the mothership in Panama, and hopefully get back online in 2024!
hi,
if you had version v0.19 on the other SD card, it should have updated to v0.20 at boot-up. if this hasn’t happened, can you download the log files again and post them here so i can have a look?
thanks,
