the station no longer exists.
Hello briansheets,
If you want to remove it from your ShakeNet profile page, then it’s not possible, as we intended it to have the entire chronology of all the Shakes associated with any user.
Instead, if you want to remove it from your “My Shake” list in the mobile app, then you can open the App, tap on “Settings” low on the right, then “Appearance”, then turn ON the slider under the “Offline stations” section.
In this way, the list will only display the Shakes associated with your account that are effectively online.
this shake was never in operation. But ok, if if can’t be removed, that’s fine I guess.
