Hello
I read the instructions of "How to connect to Raspberry Shake remotely"
I installed the ZeroTier software, and there is a Network ID. I would love to explain what I do from this point to connect remotely. I have Windows (not Linux)
Would appreciate help
Thanks
Have you also installed the Zero Tier software on your Windows PC?
If not, you need to do that and approve of its IP address in your Zero Tier web site, just like you approved of the Raspberry Shakes IP address.
Once you do that, simply enter the RS Zero Tier IP address in your web browser and it should connect just like its on your home network.
