I want to change the mechanical filter tube to use the 20-second filter. I haven’t found a tutorial or video showing how to do this. On the RBOOM outdoor version, the mechanical filter tube seems shorter than on the standard version. Should I cut the yellow tube?
Hello helenej, and welcome to our community!
Thank you for contacting us regarding this issue. We apologize, as it appears that you have been sent the tube for the indoor version while yours is obviously the outdoor one.
No worries, however, as you can cut the yellow tube as indicated by our lab team below:
And then connect it in place of the red one you have. With this, you’ll able to use the yellow 20-second filter tube with your outdoor model.
If you require anything else, I remain available.
